CineRender draws the wrong color
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2016-02-10
08:17 PM
‎2023-05-11
11:41 AM
Noemi Balogh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-02-10 08:20 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-02-10 08:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-02-10 08:39 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-02-10 08:55 PM
Thanks for the tip!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-02-10 09:04 PM
• You had a turquoise material that showed correctly using the Internal Engine and in CR
• Then you edited the turquoise to grey and since it shows correctly in the 3D Window I presume you edited the Surface Color in Internal Render.
• If this is the case then IR will be gray but CR will still be turquoise since CR does not update automatically unless you use the Match Settings option.
• That being said if CR remains turquoise even after using Match Settings then it might be that the material has a Texture with that color so changing the Surface Color will not change it until you edit the Texture or remove it.
• Also it might be possible that you need to move the camera a little bit to force a refresh.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-02-10 09:22 PM
