Cinerender - don't show backgroundimage?
Hi!
I now finally finished with our office ArchiCad 18 template and now I'm doing the first testproject to see if it works.
Now I can't get the backgroundimage to show up in cinerender, I'm only seeing the environment / physical sky.
What am I doing wrong? I'm using the default settings "Outdoor Daylight Medium (Fast)", and apply my background.
Couldn't we use background image when using physical sky?
Problem solved!
Solution for others that have similiar problems are :
PhotoRendering Settings -> Detailed Settings -> Environment -> Compositing -> Sky Visibility, set this option to OFF
