Thanks, Barry and David, for your responses.
David, your option (to set the camera Path Display Options to not display the cameras or the path) does work. I will use it.
Barry, your option (to display a path with no cameras on it) is the one I already knew about, and it does not work in this case because the camera path with the views on it keeps turning itself back on every time I click on a camera-created view.
When I save a view, the source is identified in the View Settings window, but the source field is not editable. It is either identified as <camera path name/ camera number> or as "generic perspective". I still think there should be a way to choose one or the other.
R Muller
AC 28 USA (20+ years on ArchiCAD)
MBP 64GB Apple M1 Max OS 15 Sequoia
