Learn more
Create imaging?
I can't fiqure out why the image gets chopped off. You can see that the paper/image size is large enough.
7 Replies 7
Is the proportion of the 3d window different to the rendering window perhaps? Make both the same shape and re-render again.
how do you cheak this? when I click size to 3D window it does not fix the problem
Have you tried closing the 3d window and opening it again. Maybe the 3d image has got re-centred. The rendered image should be exactly the same as the 3d window.
it looks like the problem was that the 3D window should be not maximized while creating renderings. When reduced to full size it proved that my view was wrong and that I needed to look more to the right.
It is just strange becuse when I clicked size to 3D window with proportions uncheaked it did not always work.
When you resize the 3d window, it remembers the focal point from the original centre of the window.
Simply by closing the window down after resizing it (X in corner), and then launching it afresh should ensure what you see is accurate.
Glad you sorted it eventually!
ok
