Visualization
Creating photorender projection from section?
Can I create photorender section?
7 REPLIES 7
yes.
search for cut planes in 3D.
Eduardo Rolon
and use the marquee.
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
Can you explain step by step? Please.
Eduardo Rolon
Using the Marquee define (in floor plan with the Bold option) the rectangle of what you want to see in the 3D window and hit F4 if on Mac, F5 if on PC to see in the 3D window the area defined by the marquee.
Look up in the Help Marquee, Show Selection/Marquee in 3D and the 3D Document tool for more information.
AC29 US/INT -> AC08
another Moderator
this information is available to you already
Look in your manual, or under the archicad help menu, go to the archicad online help, look in the index for 3d cutting planes, it's nearly at the top of the list.
With respect, xristina, the marquee is superior to using 3D cutting planes for this purpose because you can quickly snap the marquee to the section line in plan in order to get the cut to correspond exactly to the 2D section.
Doing the same thing with the cutting planes is tedious as you will either approximate the cut location by drawing the plane, or you will have to determine the proper coordinates and enter them.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
oh, i don't disagree...
as with so many things in ac, there are many paths to reach the same destination, each with pros & cons.
I haven't had the need to use either in this case for producing a paper drawing so can't comment with real certainty which one 's best, though i do use the marque in 3D regularly to view parts of my model to cut down on regen. time ... don't know why i though of cut planes first
