2005-12-27
11:23 PM
2023-05-11
12:35 PM
Noemi Balogh
2005-12-28 01:49 PM
2005-12-28 05:03 PM
2005-12-28 05:04 PM
2005-12-31 03:19 AM
neil wrote:First off, I agree that's it's a pretty decent rendering. A couple of things that are uncomfortable. One is the severe perspective. I would pull the eye point back with a more narrow field of vision to feel more like a standard 52mm camera lens, rather than the "wide angle" feel. The car really draws my attention and it shouldn't. That problem will be somewhat ameliorated by pulling the eye point back.
I would like some constructive criticism on this rendering I produced with lightworks. I modelled this scene very quickly just to play around with lightworks (I have nothing better to do in my holiday). Any advice on how to make it better would be appreciated.
I feel like I'm starting to get better using lightworks, although its proving to be a pretty hard lion to tame. Perhaps when I get a job, I'll be able to buy Dwights book - but until then, all I have is the forum.
2006-01-01 04:27 AM
Burginger wrote:Is there anything you had in mind that would make this rendering better? I am competent using photoshop, although I didn't do anything to this image as I felt there was not much of a need for 'post processing' in this case. Perhaps there is though?
perhaps play with post processing a little in PhotoShop.
Josephus wrote:I had a feeling this was the case. It seemed okay without the car, but now it does look pretty bad. I'm going to try again with a better view point and not such a wide angle.
Josephus wrote:Heres the texture I used. I like it because it's quite large, and it is hardly noticeable where the texture joins. Im not sure of where I downloaded it from.
The grass looks really good, you've got a good image map there.
2006-01-01 09:50 PM
2006-01-01 09:57 PM
neil wrote:
Mark, is there anything you had in mind that would make this rendering better?
2006-01-06 05:01 AM
2006-01-06 05:05 AM
