2013-10-14 07:39 PM - last edited on 2023-05-11 12:05 PM by Noemi Balogh
2013-10-15 12:13 AM
2013-10-15 02:44 AM
2013-10-15 03:31 AM
MarkMoscrip wrote:Thanks for your suggestion! However, a question came up:
Try this: render it 2 times, one with Sun on, and one with Sun off, then use Photoshop to compose into single image.
2013-10-25 01:30 PM
2013-10-29 04:10 AM
dennisjoe wrote:You meant Options> Element Atributes> Surfaces, right? There, I followed your steps, and reduced the reflectance to 0.30. When I exported to artlantis, the walls did became darker. However, if I change the reflectance back to 0.89 - the original setting, the overall brightness does note change (it remains dark)...It's worth mentioning that I had to install all the software again in a new pc, and I don't have the original artlantis file.
Go to Options> Element Atributes> Materials, make sure the Lightworks Rendering Engine is selected under Create Preview, select relevant material and adjust the Reflectance setting as required.
