Cut surfaces in 3D - Building Materials
Can someone tell me why this wall shows the surface for the building materials at the top of wall, but not at the end? Am I missing a setting somewhere?
21 Replies 21
Is it a CP wall with the edge surface overridden in the wall settings?
It is a complex profile, but all the components have the "use building material" box selected.
Also, i just created a new wall (just a composite wall) and used the same building materials. The sides and top are not showing correctly. How do I change them to use the building materials? Must be something simple I am missing...
This is my wall settings box.
James B
The override surface settings work a little different between a Composite and Profile. For a Composite Wall you have 3 surface overrides (outside/inside/all edges), for a Profile you have only 2 (extrusion override, ends). You need to depress the end/edge button in the Model panel under "Override Surfaces:" then the skins will appear.
James Badcock
Ah, it was something simple. I never knew you could depress these buttons...
Erich
Although your issue seems to be solved, I have noticed that when you trim a wall to a roof, it no longer shows the building materials properly and ends up looking much like your images.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Erich,
Can you show an image of this situation?
Steven,
A few New Feature Clips showing how this works:
https://www.youtube.com/watch?v=Vd4xGZ7zzvY&list=PLnXY6vLUwlWWTKWYR6GDMPaua0jD1JtMr&index=10
https://www.youtube.com/watch?v=hQUR-ZsdHmc&list=PLnXY6vLUwlWWTKWYR6GDMPaua0jD1JtMr&index=11
https://www.youtube.com/watch?v=x9PLDkbOGx8&list=PLnXY6vLUwlWWTKWYR6GDMPaua0jD1JtMr&index=12
Thank you Laszlo.
