Visualization
Dark Fluorescent and Pendant Lights in Cinerender
I cannot seem to get a fluorescent light to put out light. The light is turned on in the light setting (see picture) and the Cinerender light setting. I turned off the sun and the surface intensity. When I render in Cinerender everything is dark. It is the same problem with a pendant light. However, the recessed lights I am using put out light as expected. Any idea what the problem might be with the fluorescent and pendant lights? Thanks.
David Maudlin
Cheikh:
One thing to try is to increase the Light Distance, it is currently set to a bit less than 5 feet. You can compare this value to the lights that are working.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David, thanks for the suggestion. The lights are on now.
