I cannot seem to get a fluorescent light to put out light. The light is turned on in the light setting (see picture) and the Cinerender light setting. I turned off the sun and the surface intensity. When I render in Cinerender everything is dark. It is the same problem with a pendant light. However, the recessed lights I am using put out light as expected. Any idea what the problem might be with the fluorescent and pendant lights? Thanks.
