wriebe
Distorted vectors in 3D parallel view when quality is set to 'Best'
Pretty straightforward, when I have a 3D parallel view set to the vectorial engine the vectors are all distorted unless the quality is set to draft. It seems that this only happens in a parallel view, and only in hidden line or shading mode. Wireframe mode looks correct no matter the settings. It also seems like its mostly confined to objects like windows , but their openings in the walls are also distorted.
All geometry is located close to the origin.
The normal shaded 3D perspective is also clipping geometry sometimes. I found the topic below which seems to be related to this:
https://community.graphisoft.com/t5/Libraries-objects/Problem-Unwanted-cutting-plane-appears-2m-in-f...
Operating system used: Mac Intel-based Monterey 12.7.6
Archicad 28
2019 16" Macbook Pro - Intel i9
MacOS Ventura 12.7.6
2 Replies 2
CosminF
Have you looked into antialiasing settings? (Options- Work environment - Advanced redraw options? Maybe changing the parameters there might help
Also, maybe this thread can be of use:
https://community.graphisoft.com/t5/Visualization/3D-Graphics-got-worse-24-gt-27/m-p/576062#M24629
Hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
wriebe
Hmmm antialiasing doesn't seem to be the issue, had no effect for me. I'll also say that the issue persisted after restarting Archicad, haven't tried restarting the computer yet though.
Archicad 28
