Distorted vectors in 3D parallel view when quality is set to 'Best'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2025-04-09
05:18 AM
- last edited
a month ago
Pretty straightforward, when I have a 3D parallel view set to the vectorial engine the vectors are all distorted unless the quality is set to draft. It seems that this only happens in a parallel view, and only in hidden line or shading mode. Wireframe mode looks correct no matter the settings. It also seems like its mostly confined to objects like windows , but their openings in the walls are also distorted.
All geometry is located close to the origin.
The normal shaded 3D perspective is also clipping geometry sometimes. I found the topic below which seems to be related to this:
Operating system used: Mac Intel-based Monterey 12.7.6
2019 16" Macbook Pro - Intel i9
MacOS Ventura 12.7.6
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2025-04-09
08:20 AM
- last edited
a month ago
Have you looked into antialiasing settings? (Options- Work environment - Advanced redraw options? Maybe changing the parameters there might help
Also, maybe this thread can be of use:
https://community.graphisoft.com/t5/Visualization/3D-Graphics-got-worse-24-gt-27/m-p/576062#M24629
Hope this helps.
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2025-04-09 06:17 PM
Hmmm antialiasing doesn't seem to be the issue, had no effect for me. I'll also say that the issue persisted after restarting Archicad, haven't tried restarting the computer yet though.
