Visualization
Edit elements in an .lcf file
PH Architecture
How does one access the elements in a .lcf file to copy or edit them?  I would like to edit the color of a surface texture.
1 REPLY 1
Aaron Bourgoin
Invoke the Extract a Container, edit the part(s) you need and then use the Create a Container to rebundle them.
If the .lcf file is part of the Archicad package, be sure to make a backup copy as your changes will not survive a Hotfix application.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
