2023-10-17 07:28 PM
I saw in the Graphisoft page for Archicad 27, an update about the Enscape connection:
Create real-time visualizations more comfortably with the revamped Archicad – Enscape connection:
I understand from this, that we can now set any Archicad object to be a proxy for an Enscape asset, (which would be really really useful as the orange Enscape assets don't look very good), but I can't figure out how this might be done. (I do have a subscription).
Enscape assets have an Asset ID parameter, which saves a GUID for a specific Enscape asset, and it seems that this is what Enscape is picking up to link a model. But regular Archicad objects don't have this parameter.
2023-10-20 09:18 PM - edited 2023-10-20 09:28 PM
As I haven´t seen or later been able to find the feature - I was surprised by reading this post and a mention of the feature in a recently published article/promotion piece about AC27:
"It is also worth noting that Graphisoft has doubled down on its work with Enscape, the real-time visualisation software, to build a more streamlined connector. It’s now possible to map any Archicad object to any high-poly Enscape asset, giving users the best of both worlds. Enscape is also now available for the macOS platform and is available for Subscription, Forward and SSA users."
I know that it has been an object on the public roadmap but it apparently isn´t any more - all that is left is traces of a direct link. And it should be noted that there isn´t any mention of the mapping functionality in the two community knowledge base entries that mention "streamlined visualisation" - both have been edited.
So what is going on here?
2024-01-12 05:20 PM
Has anybody managed to figure this one out. It would be a really useful tool and is supposed to have been added in 27?
2024-01-16 05:18 PM
Noticed that it is marketed as a new feature directly by GS as well:
"Map any Archicad object to any high-poly Enscape asset to leverage the best of both worlds."
2026-02-10 11:19 PM
Looks like this is possible on a technical level at least - if a GDL object has a parameter enscapeAssetId with a GUID that matches an object in the Enscape Asset library (just look one up from an Enscape object in Archicad), it will get substituted with the Enscape asset.
There's a Powershell script here, that appears to be ready to read GUIDs from your downloaded assets: Script to extract every asset thumbnail into category folders for refrence - Tips, Tricks & Tutorial...
Not a fully implemented feature then, but if it is this simple, if Enscape would just query a custom property instead of a GDL parameter, this would be pretty good already...
a week ago
Anyone know what happened to this great new feature that never got released? 😅
