Visualization
Error in analytic shading method!!!
wat does this error mean. Not enough room in heap zone
4 REPLIES 4
__archiben
possibly that you have run out of hard disk space. or memory. or some other 'heap' you may have in there somewhere.
first: check your hard disk space and free some up if possible.
second: it would help to put some information about your machine, OS version and archiCAD version in your post (or signature) . . . then we'd know better where to look to help you out.
let us know how it goes...
~/archiben
b e n f r o s t
I got rid of the error message. I had to instances of archicad open and i was trying to render out an interior that i am doing. It has a heavy poloygon count. By Closing an instance of archicad i was able to get rid of the error message.
__archiben
sounds like you were out of memory . . .
glad you got it fixed up.
~/archiben
b e n f r o s t
Djordje
If you do need to do this more often, add RAM ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
