Visualization
Exporting layers
hi Guys, i have been playing around with photoshop for a while trying to do a nice coloured plan view, but it takes time to set up the layers etc. and often i make mistakes etc.
i have just got autodesk's impression and like it, as you can load a DWG. or DWF. file into it with all the layers. (DWG. files dont seem to work from archicad, but DWF. do)
anyho, is it possible to save a file from archicad and use it in photoshop with all the layers already set up?
cheers
You can save a PSD file from ArchiCAD but I don't think it is saved out with layers.
I don't have PhotoShop so I cannot check.
Dwight
That answer is "no."
Dwight Atkinson
