2006-11-15 12:03 AM - last edited on 2023-05-11 12:29 PM by Noemi Balogh
2006-11-15 12:03 AM
2006-11-15 02:21 AM
2006-11-15 12:55 PM
2006-11-15 05:30 PM
tigr wrote:I've tried this and the problem seems to be that I want to be able to see through the windows in the night rendering. The sketch render engine cannot create a sketch showing the lines on the other side of transparent objects (windows).
2. render sketch scene (Koh-I-Nor, thin black lines, best antialiasing)
3. in PS: remove white background from sketch, invert line colours from black to white (you can do that also via sketch settings - black background, white lines)
4. overlay sketch on render, adjust sketch transparency to match your needs, a bit of blur and voila.
2006-11-16 01:39 AM
The sketch render engine cannot create a sketch showing the lines on the other side of transparent objects (windows).Sure it can, look at the attached sketch - it is some cabinetry with glass doors and you can see conturs of shelf behind (of course hatch lines is a different story).
Interesting side note though, you can create an animation rendered in sketch mode. This was one of the first things I tried in Archicad and it looked like the music video from the 80's band Ah-ha.Sounds great, never thought about it, thanks for pointing this out.
2006-11-16 08:03 PM
2006-11-16 08:05 PM
2006-11-16 09:02 PM
2006-11-16 09:04 PM
