First Attempt Using Maxwell
I really don't know what I'm doing wrong with these shots i have saved out in maxwell. If anyone can help me with some pointer i'd be happy.
4 Replies 4
Dwight
really good feeling to the image.
The graininess is due to a lack of resolution of rendered energy - can you drive up the sampling or whatever they call it?
Dwight Atkinson
.....and someone stole the bed
Steve Jepson
I can tell from your image that it will be a good render.
just open it up an continue. Let it go for 4 hrs.
Then post your results on the Maxwell Render forum where you can get Maxwell help. The ArchiCAD model is just fine as it is. Nothing more you need to do with it in ArchiCAD.
Did you export with the add-on or save as .3ds and then open it up in Maxwell ?
I exported the model with the add-on.
