Visualization
Floor gloss
Carstenem
What is the simplest way to add gloss to a stone floor ? Can't seem to find the settings in AC 21+ AC 22.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
5 REPLIES 5
Carstenem
I was on the right track with width/roughness under reflection but you need to render with detailed settings to see the result.
Carsten
www.asmtechbase.com
Lingwisyer
Guru
That is not due to something like the Ray Depth setting changing?
Ling.
Carstenem
no you need the tick the details settings - general options - blurriness, otherwise it won't show in test renderings.
Carsten
www.asmtechbase.com
Lingwisyer
Guru
Oh? I thought Blurriness just toggled the distortion of of reflections and refractions... Anyway, good to know.
Ling.
Carstenem
that's what gloss is in reality so you are right
Carsten
www.asmtechbase.com
