render 2d cutouts
I wonder if it is possible to render 2d personalised cutouts of people instead of the silhouettes
that has archicad preset.
3 Replies 3
You can only render from the 3D window.
Erwin Edel
Our local reseller's subscription library has a part where you can save a slab as a custom cutout and load it much like you could save a custom door leaf and load it in a door.
No idea why Graphisoft doesn't offer that.
That said, the script is very easy, if you open one of the existing cutout objects and save it under a new name you just need to modify the script a bit. Let's say this is object A.
If you draw your silhouette cut out with a slab and save that as an object too (object B), you will have a PRISM_ script in that object 3D script. Just switch out the PRISM_ script from object B bit of script with the PRISM_ script of object A.
There is also some 2D script, but that is rather trivial, I would say.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
derekjackson
Or you could apply it to a Morph plane, and use the texture's Alpha channel to cut round it...
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
