Visualization
Foggy Windows
David Bearss
I have windows set to transparent and am using the default Cinerender Daylight settings. However they are quite foggy. I have had success before but have not rendered in awhile. I transferred settings over from a previous project that worked well but got same results. Any advice would be much appreciated.
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
4 REPLIES 4
Tray to lower the value of Ray threshold in options in render set up. Try with 1.
alemanda
First try to use a preset rendering settings (even the fast daylight) to understand what causes the problem.
Then I would check the material's rendering settings
If it is ok I would pass to your saved settings and I would check what channels are rendered (transparency, refraction , reflections, alpha, etc).
Let us know what you find
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
David Bearss
Finally getting back to this. Even in fast daylight mode glass is not clear. Works fine with sketch. will fiddle around some more.
David Bearss
Alienware 17 R5
Erwin Edel
Check the settings for the surface in cinerender engine. Sketch engine uses internal engine settings for transparancy.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
