Just wrote similar reply on other topic:
Go in to Detailed Settings, all the way at the bottom there is Options > General Options.
Look for Ray Treshold, Ray Depth and Reflection Depth.
Try setting the Treshold to 0, this will reflect everything in your scene, sometimes the cut off percentage gives weird results. Render times will increase a bit.
Ray Depth and Reflection Depth are how many layers of transparancy will be passed. I ussually have these around 12 both to allow enough windows to be shown. This will also increase render times a bit.
Regarding the example image above, the difference in reflection is due to refraction and the different viewing angles. If you want completely mirrored facade: use a mirror surface, not glass or play with the refraction settings of the glass surface until you get your desired look.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
