‎2009-12-11
03:34 PM
‎2023-05-11
12:51 PM
Noemi Balogh
‎2010-05-07 05:08 PM
‎2010-05-30 02:04 AM
‎2011-04-15 08:11 PM
Steven wrote:So, just to be clear, there is
OK, so what if I want to show a client a project by "flying" around it in 3D perspective using the explore tool, and have the siding changed to a different color?
WISH!
‎2011-04-15 08:18 PM
‎2011-04-16 12:17 AM
Steven wrote:Steve—So, did you find a way to change colors of materials so you they would show up in OpenGDL as you showed a client the model in 3D?
As I understand it, the "material" is an actual image, jpeg or similar, so no, you cannot change the color of an existing image. The "texture" of a material can be changed, this is what you would see in an exterior elevation, clapboards for example. That can be changed for any material.
‎2017-06-29 10:27 PM
