Visualization
HOW TO BRING PLAN INTO PHOTOSHOP
Please help - i know this topic has been discussed before & the answer is 'Use PDF. (EPS is a similar option.)'
But i have a problem, my archicad does not give me the option to save the plan as a PDF or a EPS
Here is a list of the options (pln / mod / mod / tpl / pln / pla / gdl / emf / wmf / sgi / psd / bmp / jpeg / pct / png / tif / tga / gtif / dwf / dxf / dwg / dgn / ifc / ifcxml / txt)
How do i save in photoshop to recieve the best quality with my save options as above? Or is there another way to save as a pdf or eps.
Thanks for your time.
4 REPLIES 4
__archiben
SIMON wrote:
But i have a problem, my archicad does not give me the option to save the plan as a PDF....
use the publisher! you can save as PDF's from there . . .
~/archiben
b e n f r o s t
OK FELLING A LITTLE SILLY NOW...
I DONT USE PUBLISHER & SO FAR HAVE HAD NO NEED 4 IT - PLEASE EXPLAIN HOW I WOULD DO THIS..
CHEERS
You can save directly as psd.
PSD is the photoshop-file.
I suggest to make your plan big enough. Otherwise the quality will be not satisfied.
Ok guys,
Thankyou all for your help,
I figured out how to use publisher.
Do u know, this archicad talk forum is great!!!!
I have just started using it - i find it so helpful.
Cheers guys
D
