Visualization
Hatch line orientation_sketch rendering engine
Jere
Hi, has anyone ran into this problem before? The image renders correctly in the IE and LW engine, but the shingles on the main portion of the roof render incorrectly in the sketch engine. Align 3d texture won't help because it's already aligned correctly.
Any idea?
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
1 REPLY 1
Sounds buggy. For a workaround perhaps you could misalign the texture in a way that will get it to work in Sketch.
OTOH it might be that the texture is rotated from its default and the sketch renderer is missing this and using the default orientation. In this case you could make a copy of the texture rotated so that it does not need adjustment.
