Visualization
Help exporting from ArchiCAD into 3D Studio max ...
ICEdevil
Can anyone help me export from ArchiCAD into 3D Studio max?
Thanx,
Dan
ArchiCAD 11 build 1210
ArchiCAD 12 Hotfix 3
AMD Athlon 64X2 3800+, 2 GB DDR, Nvidia geforce 6600GT, Win XP SP2
14 REPLIES 14
ICEdevil
Thanx,
Dan
From the 3D window, save as 3DS.
Please do not double post. See response in "Other Products"
ICEdevil
I know that...but what are the options to choose when saving in 3ds format?
And what settings to adjust when importing the file in 3dMax?
Thanx
i use on 3D window SAVES command on that dialog choose the 3D Studio format ".3DS
on the options>
Construct 3D Studio object according for the simple way for me is
Element tips - Materials
Units that is not to be easy you need to work intro 3D MAX wit Generic units
is easy way in max if you tracing shadows and GI or Photons that is necessary
i am in generic units in max who is for me = 1meter for that i set the option Set Drawing units to 1000.mm if you work in meters in AC if you work in centimeter make 100.mm if you work in millimeters 1mm
after that you open 3DS MAX an make import command choose the file who you export from AC and thats all for a materials all Library parts you need to pick him materials they type is Multi sub Object material in MAX Material editor you can change all of them
good chance....
ICEdevil
on the options>
good chance....
I am still unable to import the file corectly... no improvement after doing exactly what you said...
All that 3dstudio max imports is three axis and one arrow which i suspect is the light direction...
Djordje
Look into the Tips&Tricks forum for Stefan's tutorials on exporting ArchiCAD model to other rendering apps; that might help.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
ICEdevil
there is no such post in the tips&tricks forum and i also searched for stefan's posts and they do not cover this matter...
__archiben
stefan's website:
http://www.sbuild.com/
a "please" could also help matters?
~/archiben
b e n f r o s t
