Visualization
How do I slow down the playback
1- I wanted to see if there is anyway that we can slow down the playback speed of a movie made with ArchiCAD?
2- Is there a setting that saves all the pictures it renders into a file (to keep as a backup) ? ... that would allow one to modify with Photoshop and then compile the movie.
Thanks
4 REPLIES 4
Dwight
Any animation can be created as a series of stills.
Assemble animation with Quicktime pro or other application to control playback speed.
Dwight Atkinson
Thank you Dwight,
I noticed that while rendering, lightworks makes the stills and does some thing with them ... I wanted to see if there was a way to have them stored in a folder (with a JPG or TIFF format) for later use ... does llightowrk allow that?
Thank you
Dwight
Study your saving and compression options when creating the Flythru.
You set LightWorks as the rendering engine.
In the Flythru you specify "photorendering" as the source
In the SAVE dialog you make a folder and save the stills to that folder.
OBB VEE US, EH?
Dwight Atkinson
Thank you
Now it is really OB V US
