lagodue
How to combine rendering techniques?
I am starting a renovation project and would like to show a presentation drawing where the existing conditions in normal, hardline, straight line mode, but use "sketch" rendering for the lines showing new work. Any thotz on how to do this?
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
15 Replies 15
Super!
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Very nice. How long did it take to composite the different images?
Thanks for compliments Mixing the images didn´t take too long - just an hour or two of playing in Photoshop ...
I needed to show the elevations in a 3D fly-around video and came up with this.
The dimensions are backwards as the complete video uses the far elevation only when the camera is on that side.
I rendered 4 separate files, turning off the elevation side that was closest to the camera and repeating the first & last frames in successive files so that the final video looks as though the elevations fade out as the camera gets to that side (using transition fades in the video editing program).
If this looks useful, I can describe the technique to get an exact match of the elevation scale & position to the model.
Martin wrote:
I made this rendering with the same method as Karl - LW and sketch rendering mixed in PS ...
Great stuff!
I'm going to show it to the other folks here.
Rakela Raul
When are we going to get Karl's book of nifty AC tricks?
There's gold in them there tips...
imagine, if he explains how to do this in piranesi now
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
