Visualization
How to convert atlantis object to archicad?
guys please tell me how I can change the object format from atlantis to archicad.
Need answer please...
There is no way to do this with reasonable quality and/or texturing.
Within Artlantis, you can export the model in several 3D formats. Unfortunately, 3ds is not one of them. There is obj and skp for example.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Steve Jepson
If you must do it...
export Artlantis objects as .obj
Import .obj into 3dMax
Save as .3ds
Import .3ds into ArchiCAD or convert .3ds into .gsm
No good way to do it.
Here is a sketchup model, opened in Artlantis, exported as .obj to 3dmax, saved as .3ds, converted to .gsm in ArchiCAD. It made the trip ok.
What Artlantis parts do you need in .gsm or .3ds ?
