Visualization
How to enter custom RGB values on Surface colors??
I'm a little rusty from not using Archicad in a few years but there used to be an easy way to enter custom RGB values in the surface settings but I cant seem to find how to do it anywhere.
I'm sure its right under my nose but can someone point me in the right direction?
thx!
(FYI-I have the RGB values from Sherwin Williams and want to match them for doing colors on exterior materials--I realize its not an exact match but its good enough for my purposes)
Archicad Version 21
2017 iMac 4 GHz Intel Core i7 processor
Memory: 32 GB 1867 MHz DDR3
graphics: AMD Radeon R9 M395X 4096 MB
1 REPLY 1
You are able to use RGB cursor into macos interface :
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
