Rhea
How to make a full white model
Is there a way to set up a full white model? I am using a predifinied "White model" from 3D Styles, but even with the shadows off, I have shading on ceilings.
2 Solutions
Noemi Balogh
If you switch to Vectorial engine, you can switch off shades coming from surfaces and get a completely white modell.
Noémi Balogh
Staff Community Expert, Admin
Go to post
Gordana Radonic
Community Manager
Community Manager
Hi @Rhea,
If you would like to achieve completely white surfaces, you can change a setting in 3D Styles. It’s best to start by creating a new 3D style for this purpose, so you can use it at any time.
You need to change the 3D Engine setting to Vectorial Engine, and then turn off Sun Shadows and Shade surfaces using Sun. Additionally, you can enable Monochrome Model and even unify the Sky Color and Ground Color in the Background settings.
Then, you’ll get something like this in your 3D window:
Alternatively, you can experiment with rendering using Sketch mode and different pencil settings:
Hope this helps,
Gordana
Gordana Radonić
Community Manager
Go to post
2 Replies 2
Noemi Balogh
Noémi Balogh
Gordana Radonic
Community Manager
Community Manager
Hi @Rhea,
Hope this helps,
Gordana
Gordana Radonić
Community Manager
