Visualization
How to reset Archicad 18 CIINERENDER to default parameters?
Paopao
I think I have messed some parameters as now all the rendering via Archicad Cinerender turn out distorted. Does anyone understand what is going on here? I was trying to render a while model effect and this came out.
When all glass begun to turn out black, I twitched with some parameters: how can I reset the whole engine to defaults now?
Thanks for your help
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
Paopao
got it fixed using the customised settings for Outdoor preset daylight parameters...which isn't exactly fixing it..
There is no 'reset' as such.
Just choose a different rendering scheme and all the settings change.
If you tweak something and you like it remember to save as a new scheme so you can come back to it.
