How to transfer materials properties to another project?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-04-18
11:32 AM
2023-05-11
01:53 PM
Noemi Balogh
2008-04-18
11:32 AM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-18 01:36 PM
2008-04-18
01:36 PM
Peter:
You can use the Attribute Manager to transfer and/or overwrite materials (as well as other attributes) between files. You should also create a template file that you update as you tweak these attributes, so they are available when you start your next project.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-18 03:47 PM
2008-04-18
03:47 PM
A quick way it to apply the new materials to a fill, and cut/paste onto the new file. However, as David said, with a good template pln you can open it up via Attribute Manager to transfer everything, and is the best practice in the long run. I tend to reuse the same plns over and over (stock plans). I keep a #2 AC running all the time to copy/paste from. Anything new I come up with I add to the template file, and every time I open a older pln, I open Attribute Manager and update the older file.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-22 01:02 AM
2008-04-22
01:02 AM
When adding to my template I have been saving it as a tpl. Any advantage in doing this, or save as a pln as Rick says?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-22 02:00 AM
2008-04-22
02:00 AM
The saving method of a project is irrelevant.
Every file has an accessible .aat [attribute] file in which to spelunk and either add to or overwrite attributes of your current open file.
It is another matter how you might reliably build up a comprehensive template that accumulates all of the special things you make as you grow with Archicad. Rick is a master of this since he needs few [one?] templates, unlike me who works in unique ways and makes up oneofakinds.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-22 04:04 PM
2008-04-22
04:04 PM
Brett wrote:Really depends on how you want to use it. A template file is a "read only" so you open a new file and base it on a template then you are opening a copy to start a new project on. I tend to use "my template" file as a resting place for commonly used "pieces" (like a deck, or chimney), to copy/paste onto something I am working on. It is an aid to standardize my stock plns. At this point with AC I use Favorites extensively instead of a template file. Again, with something like a new fill, I would copy that onto "my template" pln, so it would be there to add via Attribute Manager to another project.
