Visualization
I have no experience of LightWave.. i Desperately need help
i've finished my building model useing the archiCAD... and i want to render my model useing the lightwave program (i want to make fly-through).... can somebody pls tell me the basic steps because i don't know how to use the lightwave?????
(in archicad) should i go to file->save as-> which format!!!!??? or should i go to image-> create fly-through-> which format?????!!!!.....
(in lightwave) i don't know anything in here .... what shull i dooo...
sorry for disturbing you but it's just that i don't have much time to learn a new program as my Project submission is after 2 weeks....
please try to help me ...
12 REPLIES 12
Djordje
You don't have much time for that ...
Why do you not try to do the fly through in ArchiCAD? Supposing that you are on 9, it can be quite good.
Hardly anyone can explain you how to do it in two weeks ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
well.... i'm trying to render a school buildin..... i used few objects for the external view in order to create a fly through useing the windows xp.... but Internally i couldn't reduced the amount of the objects...
Making that in LightWave will not help you so much. I suggest do it in Archicad. If you want essentially better quality (GI, or so) 2 weeks might be not enough to render the thing, not mentioning that you want to use software that you don't know at all. If you don't know how to create fly-through in Archicad read the manual, and come back with more specific questions. Good luck.
i know how to use the archicad and i've finished with the fly-through only for the external look of my building..... but i coudn't create a fly-through inside the building because widows XP gives every program a limite of 2 GB and when i create fly through internally the frames become blank... my computer can't render a file with too much objects inside..... and i don't have Mac nearby...
TomWaltz
You might want to try a few of my tips here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=50724#50724
Tom Waltz
If the limit is the size of the file, then render in segments (~1000 frames per segment ?) compress segments and join them, OR use compression (with high quality settings) from the beginning. Remember to use reasonable resolution. High resolution of the movie is big space eater.
stefan
Having no experience in Lightwave, I wouldn't do it in Lightwave to begin with. Unless this is the direction of your future carreer, then go on and dig in. But it takes a long time to master...
Do it right inside ArchiCAD. Start with smaller camera movements, not everything at once.
Render short camera moves, about 200 frames each.
Avoid geometry if it doesn't contribute (e.g. furniture).
Assemble the shorter clips in a longer presentation using video-software.
Learn by doing 😉
Show us the result, please!
Archicad-user since 1998
my Archicad Book
Thanks alot everybody....
if i want to show you my work.... my video will be long.. maybe 4 mins or 6mins because there will be a senior project exhibition.... can i attach something big like this?? i'll compress it to smaller size ofcourse....
Djordje
Not really
If you have access to a website to post it, you can place a link here, so who wants to see can download it.
So, what is it finally? ArchiCAD or something else?
Djordje
HP Omen
