‎2020-07-21
11:45 AM
‎2023-05-11
11:47 AM
Noemi Balogh
‎2020-07-21 11:50 AM
‎2020-07-21 11:54 AM
‎2020-07-21 02:16 PM
‎2020-07-22 02:49 PM
Liamthanks wrote:Hi Liam,
Hi all,
I have now twice tried to install the DirectLink plug-in for ArchiCAD 23 to no avail. Both times have resulted in me having to remove the plug-in files, uninstall Visual C++2017 and then re-install ArchiCAD, which is incredibly frustrating. I completed the exact same task today on my new work PC and had zero issues there, so I'm confused as to what is happening on my home PC.
Now before I try for a third time, I thought I would seek some advice here. What happens is as soon as the plug-in installer runs and finishes, I get an error message stating referring to Visual C++ being required. At this point in time, if I try to open ArchiCAD, I am then met with a handful of error messages which include:
- The code execution cannot proceed because MSVCP140.dll was not found
- The code execution cannot proceed because vcruntime140.dll was not found
From there, the program will not open. When trying to re-install ArchiCAD, I am then met with an error stating my OS is not up-to-date, which in fact it is. This is where uninstalling the C++ 2017 resolves the issue and allows me to repair ArchiCAD again.
Has anyone run into any issues like this in relation to the DirectLink installation?
Thanks.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-08-02 04:14 AM
‎2020-08-05 01:32 PM
Minh Nguyen
GRAPHISOFT
