Interior Rendering with LW-AC9
I'm planning restaurant interior.
I'd like to bring some atmosphere environment with warm character from wood material.
But the rendering looks quite stupid.
Cann you please help me?
For effect: no sunlight, no camera light, ambient light 50%
used lamps: downlight for small lamps, 5x sun object with 5% and yellow color, window light for the lighting wall 10% and yellow color
10 Replies 10
I put this time LW-shader for material.
General light 33%, Falloff 2, as Dwight said.
The wood looks bad. What kind of lw-shader can I use for wood material, for better result?
Dwight
post an isometric view of your lighting solution.
Dwight Atkinson
Here is iso picture.
I send to you also ground plan.
Here is ground plan with light position.
Thank you Dwight
Dwight
How is the wood supposed to look?
Dwight Atkinson
Dwight
Please clarify the plan. Whatever the overlap, I can see several sun objects.
Duh.
This must take forever to render.
Try two large light cone down light sources instead.
Dwight Atkinson
Ups sorry
That is ground plan.
sun object 5% and 16%
general light 33%, Falloff 2
and for wood such like pattern?
http://www.osmosis.com.au/visualize/papershop_01.htm
I put two light cone (in General 9 in Library) at 30% intensity.
I switched off the shadow, but very strong shadow!!
and too dark... not kind atmosphere
Dwight
Dropload your file to me:
http://www.dropload.com/
to:
dwight_atkinson@telus.net
and I will work on it.
Dwight Atkinson
