Koh_I_Noor Problem
I've noticed that chunks of wall go missing, when doing a sketch rendering
using Koh_I_Noor. These external walls are drawn using complex profiles.
Anybody know a possible reason?
Thanks
4 Replies 4
Did you remember to clean the nibs? Those pens can be tricky. 😉
Try replacing the profiled wall with a simple one ans see if the problem goes away. If so, perhaps there is a problem in the profile such as fills crossing themselves or each other.
I have something similar, the Slabs are missing and part of the door. The walls are just normal not complex.
gpowless
I've noticed that sometimes the 3d model containing composite walls misses a number of pieces to the model and that will translate to sections and elevations. I have been able to work around it but grabbing the section marker in plan and nudging it by 1/8". The model is then forced to regenerate in section and the model corrects itself.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
Yes, I have come across the same problem where drawings (from the relevent view set) when updated in the layout book have some walls in section missing even after several updates. I've deleted the drawing from the layout and replaced it with a new one, which fixes it. Not reliable though...things coulg get missed when your ready to issue the drawings.
Anyone else experience this - possible bug?
If so, Graphisoft should know about this....
