LW won't render but the background color
Hi there!
I am doing a rendering of my project and it would not render it in LW but the background color I chose like the grays or the clouds. Is it too big of a file for LW to render? Please advise.
Thanks
4 Replies 4
Dwight
How long is a piece of string?
If you are working in ArchiCAD 10, you can ask it to give you polygon count, but there's no absolute limit that I know of.
Can you make it render with the internal engine?
Can you make it show up in the 3D window?
I suspect that you have a marquee or element outside the view erroneously selected when you mean to have the entire model rendered. Ask it for a parallel view and see if the elemet shows up.
This blank screen thing DOES happen to me on occasion. I just keep trying and it finally works.
Dwight Atkinson
Thanks for your reply.
I am using AC9 and it opens in 3D window. It also renders with internal engine but not lightworks. Please advise.
Thanks.
Dwight
please post a screen shot of your project to assess complexity.
Dwight Atkinson
Good Morning,
Please see attached a .jpg file.
Thank you.
