Visualization
Library missing unused surface JPG
derekjackson
Hi, there seems to be a weird bug in the libraries / surfaces in 19 and 21.
If I use a JPG in a CineRender surface channel, referenced from my job library, it shows okay.
If I then edit the surface to no longer use the JPG (or use a different one), all is well.
But the moment I then remove the JPG from my library, it throws up a 'missing attribute' error when libraries are reloaded - even though it's not in use?!
Where does it think the JPG is being used so I can tell the surface that it's not needed? This even crops up when surfaces are Attribute Managed between projects, so it's stored in the surface definition somewhere...
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Erwin Edel
Could be a different channel in cinerender (other than the Color channel), could also be the opengl/internal engine, though that would be rather obvious.
However, if you check the loading report and press the little 'i' button, it should tell you which surface is missing the texture, just to be sure it's not a different surface than the one you are looking at.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
derekjackson
Thanks, but it's not those things. It was made specifically for one channel, and that's since been changed to 'none' and deactivated.
And the error report just says it's that surface.
We've encountered it a few times in different files with different surfaces, so it's not a one-off mistake.
Any further ideas?
AC19 / 21 / 23 / 27
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
I tried the workflow you suggested real quick: added a JPG texture to a cinerender surface, apply it, change the picture, apply, delete first picture. I get no error like this though.
I think it is either that the picture file was left on an unticked channel (so it is still in the surface, only not used), or there's something specific about the surface/channel you are using. If you could send me a PLA with this problem (and maybe a video) so that I could look into it, that would be great.
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
