2011-06-17
11:16 AM
2023-05-11
12:08 PM
Noemi Balogh
2015-04-04 04:05 PM
clairej wrote:My advice would be to not use the Window Light objects (Lamps) with CineRender, they are a holdover from the older LightWorks rendering engine (to fake Global Illumination). Start with one of the provided Scenes (PhotoRendering Settings > Scene > Select and Mange Scenes...), try one of the Medium scenes, which yield a good balance between quality and speed. You should not need the Window Light with these Scenes.
Your advice would be much appreicated as I cannot find any reference to this.
clairej wrote:When I used these with LightWorks: the arrow points into the room, and I placed them just inside the window, sized to match the window size. You are probably not seeing much difference as this source just adds to Global Illumination.
Archicad 18 Cinerender - placing of Winow lamp objects.
These are a T in plan.... is the cantral arrow of the T supposed to point in or out of the building and is the object placed on the exterior or interior of the wall line? I have tried all different configurations and it seems to make no difference in the render. I have the lamp setting on and the sun off as I have a sun object.
2015-04-04 10:22 PM
David wrote:clairej wrote:My advice would be to not use the Window Light objects (Lamps) with CineRender, they are a holdover from the older LightWorks rendering engine (to fake Global Illumination). Start with one of the provided Scenes (PhotoRendering Settings > Scene > Select and Mange Scenes...), try one of the Medium scenes, which yield a good balance between quality and speed. You should not need the Window Light with these Scenes.
There should be others on this forum with more experience with CineRender, but this is what I have discovered. You can also post some images with the CineRender Settings and maybe someone will have additional advice.
2015-04-04 10:58 PM
