2005-08-21
08:00 PM
2023-05-11
12:36 PM
Noemi Balogh
2005-08-21 09:53 PM
2005-08-23 09:01 PM
Eric wrote:One thing where Mac excels is the memory usage. If you do need more than 2GB (and you do on large models at high resolutions) you are stuck on PC, while you are not on the Mac.
I've been told by GS developers that the Mac os/hardware currently renders faster than PC's. Let's say money were no object...do any of you have any first hand experience between high-end PC's vs. Macs specifically when rendering that would justify this claim?
Thanks,
2005-09-08 09:19 AM
Djordje wrote:The 2 GB limit on PC's is something from the past. There are full 64-bit OS's (XP in beta and Linux in full), 64-bit apps (Cinema4D, Lightwave, XSI...) and 64-bit processors (Athlon and Intel).Eric wrote:One thing where Mac excels is the memory usage. If you do need more than 2GB (and you do on large models at high resolutions) you are stuck on PC, while you are not on the Mac.
Thanks,
2005-09-09 09:07 AM
stefan wrote:Until every PC runs 64 bit OS it is not.
2005-09-09 10:25 AM
Djordje wrote:Well, so many PC's still running Windows 98, AutoCAD r14 etc...stefan wrote:Until every PC runs 64 bit OS it is not.
2005-10-23 09:06 PM
2005-10-23 09:46 PM
Eric wrote:AFAIK, the ArchiCAD implementation of LW will not utilize more than two processors.
Now that the new quad G5's are out I'm curious what the multi-processor limitations of lightworks are. Can LW take advantage of 4 processors? If so, I may have to go to the apple store and run some benchmark tests.
2005-10-23 09:54 PM
2005-10-26 03:30 PM
