Visualization
Material Editing in Archicad 12 - no Lightworks?
Hi all
Tried out Archicad 12 last night for the first time but when i go to the Material Attributes theres only a drop-down showing render with "Internal Engine" and no Lightworks..? Did they change things around so that you have to edit it some other obscure way as opposed to AC 10?
As Lightworks is an add-on, I would check the add-on manager to be sure it loaded.
Make sure the box is checked to 'Use the designated add-on folder' and that it hasn't changed from the default C:Program Files/Graphisoft/ArchiCAD 12/Add-Ons
You can 'Search for additional add-ons' to verify that 'LightWorks Rendering Engine.gmx' is available in the Visualization folder.
In Material Settings select create Preview with "LigthWorks Rendering Engine" or uncheck "Disable unrelated controls"
ArchiCAD 12 INT (2156) Win XP sp3
Intel Core2 Quad 6700 / ATI Radeon HD 3870 / Dual LCD screens HP 30" + Dell 30" LCD
and
ArchiCAD 7+8+9+10+11 INT on Win XP sp3
