Maxwell into archicad 13 32bit.
Hi guys,
i have installed Archi13,in a 32bit pc,and i have installed maxwell 2.0.6 ,but the add-on does have no effect,can someone help me please?
The add-on file's name is "Ac2Mxs_Setup_v2.0.6" , does anyone has an other one?
Thank you.
2 Replies 2
Steve Jepson
I am not sure how the add-on is useful anyway. Just save your 3D view as .3ds and open it with Maxwell Studio.
If you do find some use for the add-on I would like to know about it.
I have the add-on, it works fine. But I don't know what good it is.
TMA_80
HI,
To Dferati
Are you using the INT version of ArchiCAD? if you are using a local version you must copy the add-on folder created by the plugin installation ( normally in the ArchiCAD program folder) to the one of your local version.
( or try to locate the plugin with the plugin manager)
If not,unistall the plugin , try to download the plugin again and install it.
To Steve
While the plugin has some limitations ( previewing mxm texture in the AC viewport, fire engine, )I don't completely agree with you on this Steve:
1-You have a built-in rendering plugin in ArchiCAD, where you could render direclty from AC without having to use another software. ( Unless you want to use the UVmapping in the studio application or to integrate entourage )
2-For the export , the plugin have a more adapted gemotries and materials organistation for maxwell studio. they could be exported either directly from the plugin or with the mxs that you could create using the plugin. ( mxs is the maxwell format)
AC12_27 |Win11_64bit|
