ā2016-02-17
06:12 AM
ā2023-05-11
03:52 PM
Noemi Balogh
ā2016-02-18 07:10 AM
ā2016-02-18 02:17 PM
ā2016-02-19 02:16 AM
ā2016-02-19 10:38 AM
ā2016-02-19 10:54 AM
ā2016-02-20 04:30 AM
ā2016-02-21 03:48 AM
Don wrote:After you install the goodies run the latest hotfix again.
I did notice that the Graphisoft Goodies for AC 18 says that the goodies are for build 3006 and the AC should be the same build number. I'm at 8004?
ā2016-02-21 08:28 AM
Barry wrote:Thanks Barry. So I tried to run the latest hot fix again, but it simply tells me it has already been updated and won't allow me to select AC 18 v8004. Am I misunderstanding you?Don wrote:After you install the goodies run the latest hotfix again.
This should upgrade them to the latest version as well.
ā2016-02-22 02:01 AM
Don wrote:No you are not misunderstanding me.
If goodie is located in the 'ARCHICAD 19/ Add-Ons' folder (or in any of its sub-folders), the ARCHICAD Hotfix installer will update the goodie tool. You do NOT have to download the goodie again after installing an ARCHICAD Hotfix.The only sure fire way I know to upgrade then is to re-install, add goodies then update.
