Visualization
Night rendering (in ArchiCAD - Lightworks)
I am finishing my Master of Architecture and Science this days in may.
I have design a new airport, and I need t make some night renderings - cause that is the best setting for an airport (hundreds of lights etc..)
My file is huge - so it would be out of question to place hundreds of runway lights etc.
The most important thing is to let the terminal itself be lighted up - glowing is more correct..
I know in CINEMA4D you can choose materials and make them "glowing".
As mention, I´d hope to get this rendering without using a third program.
I know some work would be done in photoshop.
SO - do some of you have a ABC/prints screen of the settings/menu regarding night rendering in Lightworks?
Thanks.
Similar example: www.instablogsgallery.com/gallery/2007/10/04/beijing-airport-1_48.jpg
www.e-architect.co.uk/beijing/jpgs/beijing_airport_fostersoct07_nigelyoung01.jpg
www.e-architect.co.uk/beijing/jpgs/beijing_airport_fostersoct07_nigelyoung27.jpg
9 REPLIES 9
do yourself a favor and do not try to achieve that in archicad.
if you can, try using 3ds max (or cinema4d) or at least artlantis (wich is very easy to use)
night renders are not difficult to set up but because of the large number of lights (and the low intensity) they demand more processing power
I would prefer to use this ambient occlusion (lookalike)technic..
I am not thinking of trying to make a photorealistic image - that is not my taste - the head thing is to make the terminal "glow" in the dark..
Dwight
Large diameter light cones shining outward from inside the windows could be used to do the beijing airport image.
Dwight Atkinson
stefan
If you want to stick to ArchiCAD, good luck with it...
I can advise you to place different light groups on different layers, make a few renderings from the exact same viewpoint (with each render using a different layer combination) and then use Photoshop to layer them together.
Easier to control a series of lights independent of the others.
Archicad28/Revit2024/Rhino8/Solibri/Zoom
Archicad-user since 1998
my Archicad Book
David Maudlin
Fiuni:
For some of these elements (like the skylights) you could try editing their material definitions, using the Pipeline > Graphisoft Emission to get the glow without using light sources.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Is it possible to create a Ambient Occlusion rendering in ArchiCAD?
Eduardo Rolon
Nope.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
ArchiCAD can do night renders pretty well, i find just placing bright general lights behind the windows and glass panels to 'over illuminate' the interior gives a satisfactory effect.
then you must turn off the sun
then apply a dark background(dusk, night ect..)
then make you skyobject or ambient light match the color of the background(night time=dark blue)
just some old preliminary renders
Thanks for good suggestions..
