β2004-04-20
12:04 PM
β2023-05-11
12:42 PM
Noemi Balogh
β2004-04-20 05:19 PM
chris_pap wrote:VIZ & 3ds max can create materials, but they also have a complete modeller, animation tools, full access to all parameters (which VIZ Render does not have).
Stefan,
I occasionally use ADT 2004 which comes bundled with VIZ Render.I am not sure about how similar VIZ Render is with VIZ 4 or 3D Studio Max.
The thing I like about VIZ Render is that I can add materials from ADT and also I can create my own materials based on pallettes (bricks,rocks,earth,etc.). Plus the fact it has ready-made materials like concrete,bricks,metal and stone etc..
Does VIZ 4 or 3D Studio have this ability?Can I create materials?Do they have materials pre-installed that I can use?
chris_pap wrote:Export the ArchiCAD model as DWG (do it from the 3DWindow to have it in 3D and then open in AutoCAD ADT2004 and link to VIZ Render.
Do you know of a way to import a building I created in ArchiCAD to VIZ Render? (It only opens .drf extensions) but can "merge" .max extensions as well. If I save my 3D perspective as .3ds from Archicad and import it in ADT 2004,when I try to link it to VIZ Render only the camera and the lights appear. Any tips on that?
Thank you in advance Stefan
β2004-04-20 06:42 PM
β2004-04-20 08:15 PM
chris_pap wrote:Cheaper than Artβ’Lantis shaders?
Yes thank you very much..It is clear now that I should get 3D Studio.
β2004-04-22 03:20 PM
Djordje wrote:I don't think so. He'll probably convince you to buy subscription with it and then you are an eternal paying customer.chris_pap wrote:Cheaper than Artβ’Lantis shaders?
Yes thank you very much..It is clear now that I should get 3D Studio.π Your Autodesk dealer must be crazy ...
β2004-04-26 09:32 AM
β2004-04-26 01:52 PM
β2004-04-26 03:57 PM
β2004-04-27 02:21 PM
β2004-04-27 02:46 PM
chris_pap wrote:That is the trick
...I must say that the results are pretty satisfactory to me...
