vfrontiers
Polygon Corners ROUNDING?
I am working on a model in 12. There are several forms that have essentially a BULGING wall connecting to a straight wall where the corner wants to show as ROUNDED instead of sharp?
Did I miss something? There seems to be no way to UN round it?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
9 Replies 9
vfrontiers
.... they are rounding only in 3d window openGL mode. Probably in RENDERING also, just haven't checked there yet.
Plan looks fine..
Duane
Visual Frontiers
AC3.14 - AC29
Screenshot? Not sure what you mean, Duane.
PS Since you have GarageBand in your sig and I know you do keyboard... I picked up an 88 weighted key M-audio keyboard for under $200 that works great with GB. What are you using?
vfrontiers
This is what I mean....
Duane
Visual Frontiers
AC3.14 - AC29
Any chance you have a slab with rounded corners sitting below those walls?
Pretty sure you get the same effect on column corners in OpenGL at times. I think it renders o.k. though.
vfrontiers
bugger.... I've been pretty successful showing clients OpenGL walkthru's during the design process...
This didn't happen in 11
Duane
Visual Frontiers
AC3.14 - AC29
Dwight
To minimize rounding consider:
make surface duller.
turn off smoothing.
turn off highlights.
Dwight Atkinson
vfrontiers
Thanks Dwight.... It's definitely the SMOOTHING button.. Unfortunately it really shows SEGMENTED along the curves that I want smooth...
Duane
Visual Frontiers
AC3.14 - AC29
Dwight
So leave an RCH at the intersection and it will return square.
Dwight Atkinson
