Visualization
QTVR Rendering Errors
Hi All,
I'm using ArchiCAD 11 and trying to create a VR of a 3d model i've created.
I've done it many times on versions 7 and 10, but seem to be encountering errors with 11 and was hoping someone had a solution.
The settings I'm using are: QTVR 2.0 Engine, Photorendering Window, True Colour - 24 bit, Compression type Animation (Millions of Colours, Best Quailty). As mentioned I have used these on other computers and version with no problems.
The only things that are unquie to this machine are, Windows Vista and AC 11. I have also downloaded and installed the latest version of Quicktime.
I have tried other options such as DV-PAL and while it works the quality is very poor no matter how I change the settings.
The error code of the Quicktime file is shown attached (but the rendering does take the normal time to produce)
Djordje
It is Vista.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Is there a fix to it or am I doomed to wait until Apple / Graphisoft release an update for an OS thats a year old now ??
