Visualization
Render your model with built-in or 3rd-party solutions
QTVR Rendering Errors
Hi All,
I'm using ArchiCAD 11 and trying to create a VR of a 3d model i've created.
I've done it many times on versions 7 and 10, but seem to be encountering errors with 11 and was hoping someone had a solution.
The settings I'm using are: QTVR 2.0 Engine, Photorendering Window, True Colour - 24 bit, Compression type Animation (Millions of Colours, Best Quailty). As mentioned I have used these on other computers and version with no problems.
The only things that are unquie to this machine are, Windows Vista and AC 11. I have also downloaded and installed the latest version of Quicktime.
I have tried other options such as DV-PAL and while it works the quality is very poor no matter how I change the settings.
The error code of the Quicktime file is shown attached (but the rendering does take the normal time to produce)
2 REPLIES 2
Djordje
It is Vista.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Is there a fix to it or am I doomed to wait until Apple / Graphisoft release an update for an OS thats a year old now ??
