Kristen
Quick render
Hi all!
I have just begun using AC10 after upgrading from 8.1. I am unfamiliar with all the finesses of Lightworks rendering engine.
I wish to do some internal renderings of a very simple model that does not contain more than a slab, walls, roof and some furniture (that does not contain too many polygons).
I am using the lightworks sun, and have placed a skyobject, a weak sun lighting upwards, and window lights to get light indoors.
My biggest problem now is that it takes 5 minutes just to do one tiny little rendering even though i have low resolution, a small window, normal method and fastest antialiasing.
What more can I do to produce a quick render to check my lighting setting and materials, instead of one that takes 5 minutes?
I saw the very fine rendering which Mehdi Blanchard posted
http://archicad-talk.graphisoft.com/viewtopic.php?t=11688
about the LightWorks DVD tutorial and he wrote "Renders like this one are generated in less than 5 minutes by LightWorks, which gives you plenty of time to adjust your settings and refine your design, without having to switch to an external application".
I wish to get the DVD but until then, I want to be able to do exactly that....how?
Kristen Broberg
AC 23 SWE Full on Windows 10 Pro
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
4 Replies 4
Rakela Raul
Dwight Atkinson
Get Dwight's book "LightWorks In ArchiCAD:" with special ArchiCAD 10 supplement.
PAYPAL: www.paypal.com: FUNDS to: [email protected]
US$95.00 in NA. US$115.00 elsewhere
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Dwight
Kristen:
As the author of "LightWorks in Archicad," I don't believe him either. Perhaps buying the DVD will provide the answer, but you can get high quality rendering information in my book at much less cost. And I freely share my information on the forum.
You problem is that Window Lights do not actually light the indoors - they just make a glow on the ceiling. They will be your time eater.
The window light is a dangerous light source because as you increase size and quality of its output, the number of individual light sources contained within it grow. You can anticipate this using an isometric preview in the lamp object window.
Use a general light source or a light cone down to illuminate the interior. Like in my book.
Quick renderings - use a tiny window.
Dwight Atkinson
Kristen
Thanks for the tip Dwight,
I am recommending that my office purchase your book (and the DVD). In the meantime, could you please recommend which settings for either the general light source or light cone I should use so my source is not too strong so it is obvious, but the interior is well lit.
_____________
Kristen Broberg
Kristen Broberg
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
Dwight
How long is a piece of string?
Moderation is the key.
Place a light cone down at the ceiling height, make it the size of the room and have the light rays fairly parallel - see the cone shape in the preview for a hint - a power of fifty is a good place to start.
Post your final result for admiration or ridicule.
Dwight Atkinson
